The fridge would not be considered as being on Habitation Electrics. Same as in a caravan where the fridge is powered on a separate circuit.If habitation electrics are disabled..
Surely that would mean no fridge on 12V....The alternative being to power it by gas whilst running. I suggest this is more risky and potentially catastrophic !
The fridge 12V power (as opposed to its electronics where applicable) is from the Starter Battery (via towbar on Caravans) also.
There was mention of the Sargents 'small controller' turning off the electrics? The Sargent units have one low-current supply that is a permanent 12V and is designed to be used for the Fridge (electronics & light - not power) regardless of engine state. That supply is often used for a radio but really a bit small.
If you DID have a setup that disabled ALL Leisure Battery power and the fridge was an AES type auto-selecting fridge whose electronics were on a Leisure Battery supply (that scenario would be extremely easy to build without thinking), then the fridge would stop working on ANY power source, including Gas.
