The RMT7655L is a fridge-freezer, nothing to do with an oven-grill, so searching on that model number draws a blank. Part 40716574 produces very few hits. Is it possible that the part number is in fact 40716571? Having the oven-grill model number would facilitate checking compatibility.I have a domestic fridge freezer and oven and grill modal RMT7655L and I'm looking for a new oven and grill switch or valve the part number is 407146574 a refurbish one would do any help would be much appreciated thank you Big Al
I stand corrected. The only potential source that I have found is https://www.leisureshopdirect.com/c...api=1&pro_id=1&mod=rmt7655l&illustrationid=98Thank you for your reply but the hole thing is one unit the dometic part is 407146574 i have seen the part number ending in one on eBay the only thing I can do is contact the seller and ask them if the part they have was off the RMT7655L I will let you know how I get on with it cheers Big Al
I would recommend Leisure Shop Direct too, bought a few things from them.I stand corrected. The only potential source that I have found is https://www.leisureshopdirect.com/c...api=1&pro_id=1&mod=rmt7655l&illustrationid=98
Their part number is 246399 and they state: "This is a factory built-to-order item. The ETA is usually 1-3 weeks but we will confirm this with you after you have placed the order."
