Papillon
If you value your life I can only recommend a gas safe engineer sorts that out urgently. The hoses appear to be past their life unless i'm mistaken the date stamp is 05.
Absolutely. I wouldn’t trust an out of date hose on any gas. Propane stored at 24C has a pressure of 120psi, for me a hose with a rupture protection device is a must.If you value your life I can only recommend a gas safe engineer sorts that out urgently. The hoses appear to be past their life unless i'm mistaken the date stamp is 05.
One of these:What's one of those?
Is it legal in the UK to drive with the gas turned on?One of these:
https://www.autogasshop.co.uk/truma-450mm-rupture-protection-hose-1023-p.asp
If the pressure in the hose drops beween the bottle and the regulator it shuts off the supply, easily reset by pressing the green button. Usually used in conjunction with a crash sensor regulator which also has a green button that needs resetting if the pressure drops on the supply side of the regulator. You need both if you are going to drive with the gas turned on.
I believe it is but you need the full crash protection kit. This includes the rupture device mentioned to protect the high pressure part of the system and a crash sensitive regulator to shut down the rest. When my mh was delivered new it was equiped with these devices and the usual warnings about turning the gas off were missing.Is it legal in the UK to drive with the gas turned on?
