RichardHelen262
The good thing about using under slung tanks is they are only taking up unusable space
I recently went to Autogas 2000 intending to have 2 x 11kg steel cylinders installed. Ended up with 2 x Alugas 11kgs as the price difference was under £60.00. Well worth it for the weight saving imho.It is, but you soon get used to doing the swap over!
When I build my next van, unless the Norwegian manufacturers of the SafeFill tanks make the sensible decision to make their tanks with 2 take off points like the Alugas cylinders have, I won't be buying another one and would buy the aluminium one instead.
Personally I would never have/but a steel cylinder on weight grounds alone and likewise wouldn't consider installing an underslung tank as I simply don't like them.
Doesn’t that depend on the van you get re weight of steel bottles. A Gaslow 11kg bottle is 12.4kg and isn’t the Alugas heavier than Safefill at over 5kg? Under 15kg for 2 x 11kg bottles saving, could be important if tight on payload but expensive saving if not?It is, but you soon get used to doing the swap over!
My only criticism is on my system both bottles are connected and it means I can’t wait until one is empty then switch to the other ,which in turn would give me plenty of time to refill the first.
Unfortunately I can’t turn one bottle off as they are both permanently joined together the outlet on one has the regulator and the other one has nothing connected to it I suppose you could use it for an external barbecue! .both bottles are joined by a separate connector which is in turn passed back to an external filling point.perhaps it is just an old system but it still works well.All you need to do, is keep one bottle turned off, until the first is empty, or what we do is we know roughly how long a bottle will last and we swap over before the first is empty
Yes both bottles have the normal shut off valve on top one for the regulator and the second bottle tap isn’t used but as both are joined to the refill point by a different pipe you can’t isolate one from the other.Surely each bottle has a stop tap, a turn knob to turn the gas off.
Maybe you could post a photo of your set up
Are you sure these are proper refillable bottles not a previous owners bodge up with bottles intended for exchange?Yes both bottles have the normal shut off valve on top one for the regulator and the second bottle tap isn’t used but as both are joined to the refill point by a different pipe you can’t isolate one from the other.
