Removing a 2010 Peugeot Boxer Engine. Possible on a Drive?
Wissel
Hey all, last year my 2010 Peugeot Boxer blew up. I'm wondering if this could be replaced on the driveway where it sits.
I know some engines need to be taken out of the bottom of the van, but sure I remember reading the front can be taken apart on Sevel vans and the engine lifted out?
If it can be done on the drive, I'll get some help to remove it and then have the engine looked at by a pro to see what the best way forward would be. This would be complicated with a garage as we live in the van.
Remember when refitting put new driveshaft seals into diff.id also renew the clutch .
If it’s a second hand unit you are fitting replace water pump tensioner if it’s got one some are tensioned through the water pump any pulleys and all belts this is good engineering practice in my experience
All the best
