Not sure when reading your message, if you mean the full outside frame or just the plastic window, if it's the frame remove inside finishing frame fixings remove and there should be screws holding the outside frame, looking at a pic from van roof to window frame looks as if there is gaps, it should be non setting you can buy it on a tape, or buy a tube of it, but not everybody uses non setting, or is it the black seal, and if so is there not fixings on the two hinges on the outside, as previous message said more pics would help, and a reply,
