UFO
Dave - thanks for this. It looks like ours is slightly different as there is sealant between the roof and adaptor and also sealant between the adaptor and the heki - see the photo, unless the adaptor is glued to the roof and the joint is covered with sealant, which would be overkill. As it is fitted is original as we bought the van when it was 5 months old.OK, just seen this post. I had the same problem in July this year on our 2010 Adria Twin (manufactured 2009).
As you say, there is a piece of plastic which turns the corrugated roof into a flat roof for the heki.
This plastic piece is glued to the roof with a strong adhesive and you will not remove it without totally destroying it. First, identify where the leak is.
I am not even sure there is a leak as it is difficult to tell what is a bit of condensation between the metal roof and ceiling boarding, it's not very well insulated - as seen when taking one of the roof lights out. What was your leak like?
I need to find time to investigate further.
