RM4271 Gas Fridge.
  • Thread starter Thread starter Piglet
Piglet
We have a RM4271 3 way fridge that has a problem when we try to use the gas only, on the other 2 it’s ok, that’s when we are traveling and on EHU the part we are trying to locate is ....Relgnitor Eletronic this little gizmo sends a charge to the pitzo Hoping you may have come across this somewhere. Thanks in advance John.
Is it this one stocked by Inter-Spares ...........
There are cheaper items on eBay, around £70, but you’d need to check the part numbers for your model.
Dave
Hi yes I think that is the correct one, I was just trying to see if I could get it any cheaper? Seems a lot for an older Moho but I may have to bit the bullet. Thanks for your help, John
Dave
Not sure if my other message went to you, I think it is the right one, but was trying to get it cheaper. May have to bite the bullet. But thanks for your help. Cheers John
Such "specialist" parts and I add burners and Gas Control valve are inevitably costly due to "small turnover" and the fact they havee to be kept available. Some items may fit many models but in some cases just finding the right part is enough !
Not cheap but compare with buying a full replacement fridge and is it possible to get the old fridge out of the vehicle !
Our fridge is 13 years old We run it on gas 80% of the time.
Last summer we needed a new burner so roughly £150x2 (including labour)
No Complaints !
Point taken, £100 compared to a new fridge on contest. Thanks for everyone’s imput very great full.
