Cheers I've just emailed with some contact details.Hi Mike, pm me on tr0114.tr@gmail
It caused a lot of problems on my rears wheels last year, the previous owner had it put in. I had a slow puncture, tyre fitter found it had corroded the rims causing the leak and gummed up the valve completely, a few months latter the other one started leaking the same, not so lucky this time, couldn't clean up the rusted rim enough to stop the leak so new rim had to be bought - Only gave me punctures not saved me from puncturesYes the old stuff used to corrode the rims and it was a nightmare to clean rims but puncture safe is the only one on market that doesn't set or crust and is non toxic so just needs washing off and then rim drying but a lot of fitters just think all products are the same, the main objection is that they are losing out on puncture repairs. Side wall rips will always be a problem but at least with ours it will stem the loss of air so you can drive to a safe place to get the tyre changed
Hi Mark, really sorry but I will not be able to make the Green Frog over the week end , I've got some unexpected family stuff to sort out which is stopping me from getting up. Where are you based and I'll see if I can get a local distributor to contact you and offer the same deal or I may be able to call over myself.I am interested, I will be at The Green Frog 11th - 15th Oct, travelling up the M6/M74 though. If you're on site at Moffat I'm in.
Thanks Mike
Should have shotblasted the rims and two pac epoxy primed them,i used to do lots of taxi rims.It caused a lot of problems on my rears wheels last year, the previous owner had it put in. I had a slow puncture, tyre fitter found it had corroded the rims causing the leak and gummed up the valve completely, a few months latter the other one started leaking the same, not so lucky this time, couldn't clean up the rusted rim enough to stop the leak so new rim had to be bought - Only gave me punctures not saved me from punctures
