Snapped ECU pin stuck in plug - Nooooooooooooooo!!!!
iansl
I think I may have found the source of my airbag light and I dont believe it could be any worse. I disconnected the airbag ECU and there are signs of corrosion in there and one of the pins from the ECU has broken/corroded into the corresponding plug.
I cannot think of any way to get this pin out of the plug as there is nothing to get needle nosed tweezers or pliers on to. I also suspect if I could get hold of the pin, there is a reason its come off, its probably corroded in some way to the plug on the other side.
This leaves me in a rather crappy situation. I cant buy a new ECU as it couldn't be plugged in anyway unless i can somehow replace this rathe specialist plug. Its the type of plug with a lever to attach it too so not a common thing.
The only thing I can think of right now is to open up the ECU and solder a wire to the corresponding connection inside and then try to find the corresponding wire in the loom to connect to.
If anyone has any idea of where I could buy a new 24 pin plug to replace the one I have or if anyone has any other solutions I would appreciate your input.
Thanks people.
It looks like pin 7 by the way. If anyone knows what wire this corresponds to in the loom I would appreciate it too.
Can you not get the back of the plug off? I think soldering a wire into the ecu is a pretty decent idea.
