maingate
What you need is the Schaudt LR1218 solar regulator, which is compatible with the EBL systems. It is a high quality PWM regulator but I believe Schaudt started making a 1218 MPPT regulator recently. If you buy either one, it comes with a fitting kit that means it charges Hab AND Engine batteries from solar.
Your 30 Watt panel will not be an original Hymer fitting and will be an aftermarket one.
