Mobilvetta
When the flexible panel was tested it was knackered, they have fitted me a solid 130watt solar panel on an aluminium frame behind this one, as we were going to Spain, so they squeezed me in, they didn't have enough time to remove the flexible one and fit a second panel for me, so they have booked me in to have another 130 watt panel fitted in May. I also had them change the controller to a victron mppt with Bluetooth.hopefully it was just the original plastic shipping film. Reminds me of the ones you get on plastic number plates ... I fitted a new plate and forgot to remove the film and now it is both peeling in places and stuck hard in others.
If you do need another panel, it looks like the two metal strips there could be ideal in securing a replacement down.
Question for you .... It looks like those strips are screwed down to the roof by multiple screws, so look secure. But they don't seem to have any kind of sealant over the screws? If that is the case, each of those screws is a potential point of water ingress .
On returning back to the UK I decided to have a go at removing the flexible one, the screws didn't go through the roof thank goodness, they were just used to secure the upper aluminium trim to the lower trim that was then glued to the roof. Also the panel.itself was glued to some plastic boards that were also glued to the roof, took me 4 hours to get it off and the adhesive that had been used. I have to say that the 130 watt panel seemed sufficient for our use in Spain, keeping the two batteries topped up, but with many dull days in the UK hopefully the additional panel when fitted will keep on top of the job here.
