Carrerasax
What about an inflatable air pump?
Should I do taps and drains?
Ha ha far better not to post an opinion on these type of threads or the law of sod intervenes. As I don’t have a drain down tap I will keep using the van insteadQUOTE="barryd, post: It'll freeze now wont it?
Yes barryd You may have just shot yourself in the foot
How do you blow your pipes out ?
And this is why I love you twoAccording to Lauren Becall, you just put your lips together and blow
Too early really isnt it? I Wouldnt have thought the odd overnight drop to zero would do any damage. We may use the van again at Christmas so will just keep an eye on the five day forecast. First three years we had it I Didnt even know about draining down and never bothered. It'll freeze now wont it?![]()
I would have thought though that the odd -1 or -2 unless its prolonged would no cause a problem in a well insulated van. That really bad winter about seven years ago though I did drain down but you never get it all out do you? Off we went for Christmas in a winter wonderland Lake district. Its snowed and everything was frozen including a couple of small pockets of water in our pipework buried deep and out of sight which meant no working taps for several days. Even with a constant warm and cosy van it failed to thaw out until I guessed where the blockage was and directed a fan heater at that section for several hours and eventually the blockage melted with no damage. Unusual circumstances but it goes to show you can never drain down 100% properly (least not on my van). Moral of the story, in Winter, dont wait until you arrive somewhere to check everything is working.
Very true but mine's a British tin can
Mind you, apart from the washing-up bowl incident, I've never had a freeze problem... touch wood, fingers crossed, touch wood again and a quick prayer to the camping gods![]()
Mines a British van as well, Kontiki 640 but its well insulated with internal tanks. In some respects a well insulated van could be worse in a really hard freeze like we had that year as eventually any water will freeze and the further buried it is the harder it is to defrost as I found out. Didnt spoil our Christmas though. It was a fantastic winter break that year. -17c on New Years eve on the Honister Pass.
Wow! That's coooooldReminds me of the time when the Southern Frosties got their name. They were at Stonehenge for -12c nights (or was it -15, I forget) and Hippy's coffee froze solid in the cup!
I know I always joke that my van is cheap, cheerful and tinny but to be fair, she's really very, very cosy and, like you, has internal tanks. I always thank my stars that I've got a brilliant old Truma gas fire that gets everything lovely and toasty without any leccy required, so I'm happy to camp during the freezing weather. The floor gets a bit nippy in winter, so I put down a 'fitted' carpet that I cut to shape from house leftovers and then put my rugs on top... makes a world of difference. The bathroom is always cold but fine if I remember to leave the door open. One thing I couldn't do in the winter would be to sleep in the overhead... the insulation doesn't feel as good there for some reason.
Yes, I dump on way home hoping vibration will empty all when travelling up and down hills. Will have to fill up again next week before setting off to NEC Classic car show.I do it before I leave to come home or in a lay by. By doing it before I get home my theory is that the drive home will shake out water from the pipes.
I do it every time if there is any possibility of freezing. A pain but better than the alternative and you get into a rhythm
Always dump when not in use . and never tie up a dump valve .
If you have a toilet that takes water from main water tank it will freeze if system not drained.
Also a new boiler will cost 2k .
Drain down it's 5 min job .
NO BRAINER .
