alwaysared
While I was at Hereford the developed a small but continuos drip from a small pipe near the Truma Combi 6 heater, I asked the Truma guy at the NEC show about it and he said it would be the top elbow and was quite common. So I traced the pipe back and low and behold it was a smzll pipe going to the top elbow which also connects the hot water out pipe. I did a search on Google and it does seem like a lot of people are having the same problem so I go to my local caravan store and buy a new one, come home, fitted it, filled up the water turned on the heater and as soon as it started to heat up the pipe starts dripping again! So does anyone have any suggestions where to look next. The leaking pipe is a breather pipe and is intended to allow the draining of the system.
Regards,
Del
Regards,
Del
