Wrighpm
Did not have any suitable oil - will just try this for now and see how it goes. I was thinking of dry graphite powder - just don't want crap to stick to lube.Did you not re-lub seeing you were in there?
Just got the van back this morning, too late for Goosnargh, sadly - it was the Truma Gas Regulator at fault.I am having the exact problem as original post. I fixed mine by firing it up with the gas isolator closed. This went through a purge/start up cycle and did not light. I then turned the boiler off, switched gas isolator back on, switched boiler to HW and heating (60) and it stayed on. ! This must have cleared something in the gas supply side I assume. This was after 2 hrs faffing and constant red lockouts.
It seems that lock-outs can occur for a variety of reasons (many stated in the post previously). In additrion to voltage/gas supply etc. also note that the blades of the small 3 " diameter fan that cools the PCB need to be kept clean as if it spins slowly it is detected and a lock-out (red light) can occur.
Also - finally - if your boiler has an electrical heating element then the physical overheat trip may have operated - this is accessed via a small peephole and can be re-set by inserting a 3 inch long probe and pressing gently.
However I would be very interested in the procedure you state above Vanity, please share. Thank you.
It would be great if Moonshadow could share the final fix too.
Ok thanks - another one to watch out for. Boiler was telling the truth then ...not enough gas detected?Just got the van back this morning, too late for Goosnargh, sadly - it was the Truma Gas Regulator at fault.
Hello vanity, can you help me with my trumatic c 6002. I have the problem that you described it doble click and then turn red.Here's how to check/oil the burner fan in a 6002.
According to the Truma tech who fixed mine, it is a common fault as the assembly is hot and the oil in the bearings dries out.
I have now done it 3 times in 5 years (lots of use!)
Symptoms - after switch on, runs for 20 secs. There's a click as the gas valve opens followed immediately by another click and the red light.
The burner assist fan is as shown.
1. Remove the cable from the fan
2. Remove 6 small torx screws around assembly. There are also two which hold the fan cover.
3. Carefully remove fan assembly. There is a sensor at the far end - be gentle.
4. With the unit out, remove the fan motor cover. You can't remove the fan blades but if you are feeling confident, remove the motor mounting screws which will allow the motor rotor to be removed and give easy access to the bearing.
A LITTLE light oil on each bearing. NOT WD40 or similar!!
5. Check fan spins nice and freely and reassemble in the reverse order.
Any questions, please ask
Sound like what I got with mine once and that was low volts, you turn on, it runs the fan to purge the system, then a click as the solenoid/s open the gas valve, then a click and a red light, I went to Truma in Derby twice, they ended up putting a new PCB in but that didn't work either, it's 12 years ago and I can't remember what the actual fix was but a temperature sensor rings a bellHello vanity, can you help me with my trumatic c 6002. I have the problem that you described it doble click and then turn red.
I tried today for the first time to run in winter mode without water in the heater, I ran for 10 min and click for trying to make hot air, and suddenly it shuts down with the red lamp. And know i can hear it turn on and open gad value and 1 click first and 1 click after.
Do you think it is because dry bearings ?
I have a video I don’t know if I can upload it here.
Regards Lasse
Regards Lasse
I have checked there is no lov voltage.Sound like what I got with mine once and that was low volts, you turn on, it runs the fan to purge the system, then a click as the solenoid/s open the gas valve, then a click and a red light, I went to Truma in Derby twice, they ended up putting a new PCB in but that didn't work either, it's 12 years ago and I can't remember what the actual fix was but a temperature sensor rings a bell
Different heater so not relevant but it was inside the cover, and it was an overheat sensor so not your issue probably.I have checked there is no lov voltage.
What temperature sensor did you replace ?
