Chasn
My Carthago has one small whip aerial used for both radio and TV. As these are two different frequency bands the use of one aerial for both is bound to create performance compromises. Considering it is non directional the performance for TV isn't bad. Taking a closer look at the aerial it appears that its size is optimised for TV. As a result the radio performance is very poor. Has anyone modified their aerial system to overcome this issue?
Having taken a short look at ways to overcome this problem I wasn't able to locate the junction box which acts as a splitter for the aerial output between the two outputs (radio and TV). The TV on my Carthago is located in an upper locker. I am considering using a Vision plus 570 aerial. With careful placement I think that there may be just enough room for the retractable aerial post inside the TV locker. That way the TV no longer needs the existing aerial and it enables the use of a directional aerial. To improve the radio performance I have had a suggestion to unscrew the existing aerial and replace it with a standard rooftop car aerial.
Comments please.
Regards
Nigel Charles
Comments please.
Regards
Nigel Charles
