DiAndy
My TV no longer finds any channels. Worked fine on last trip. Is there a tester I can acquire to see if a signal is reaching the TV. Need to determine fault is either the TV or the booster or the aerial.
I use one of those Bill, because the TV needs tuning and the aerial needs to be pointing at the mast a signal finder is useful, before I use it I look around outside to see if any areials are visible thoughYou could test the signal from the aerial with something like This
not just a pole..in fact any eastern european will gladly hold the aerial in the right direction for a very reasonable hourly rate...Can't beat the old aeriel on a pole .
