I would recommend fitting a tyre pal Gordon, gives up-to-date tyre pressures on a monitor screen and you can set an alarm to warn you if a tyre starts loosing pressure. Worthwhile investment and a good discount if you get a code from a member of the camping and caravan club.Just done my tyre pressures and it's a good four months since I last tested them and pleasantly surprised how close to Manu recommendations they were
What I use too, did save me on one tyre.I would recommend fitting a tyre pal Gordon, gives up-to-date tyre pressures on a monitor screen and you can set an alarm to warn you if a tyre starts loosing pressure. Worthwhile investment and a good discount if you get a code from a member of the camping and caravan club.
Used to test everything before every journey, now just look at the instruments in front of me, they tell me everything I need to know, just have check there is no cat under the van.How on earth did we manage years back without all these gadgets.
Don't you think I would notice migrants, they are a lot bigger then a cat?, I'm not talking about a Lion or TigerEven pilots do a walk around before flight, they have 10 times the instuments you will ever have, & do the instuments tell you if a migrant has wrapped himself wife 4 kids around your back axle.
I thought you were still using solid tyres?How on earth did we manage years back without all these gadgets.
