Depends entirely on your system!Is it worthwhile adding a VB battery master too your system,many thanks for any answer.
The latest BMs have been updated to work better with Lithium, but basically they are/were setup to activate above a certain voltage and that voltage is below the normal Lithium voltage - so result was they would not go on when solar or EHU is active, but just stay on all the time.Depends entirely on your system!
I used one successfully for several years with AGM leisure batteries, but @wildebus recommended replacing it for technical reasons when I upgraded to LiFePo4 batteries.
