Victron MPPT 100/30 advice please
alwaysared
I have two 130 watt solar panels connected to a Victrom MPPT 100/30 which is connected to Leoch Adventurer 130AH AGM battery and my question is what preset in the Victron should I be using for it? Any advice is appreciated.
Kind regards,
They don't make it that easy to find the core info, but looking at the datasheet here - https://www.alpha-batteries.co.uk/media/catalog/product/l/a/lagm-130.pdf - I would go for these settings:
Absorption Voltage - 14.4V (allowed range - 14.4V - 15V)
Float Voltage - 13.5V (allowed range - 13.5V - 13.8V)
Temp Coefficient - -20mV/Cel (recommended -30mV Charge, -20mV Standby)
If your 100/30 is the SmartSolar model, you can set the exact parameters you want, so could set the above if you wanted. If you have the BlueSolar only, then you are limited to the presets.
On the Presets above, the default setting (2) is the best match:
Absorption = 14.4V, Float = 13.8V. The temp coefficient is maybe a little more than you want though - 32mV/C, so in float mode you could be putting in too high a voltage at typical UK temps.
I use the AGM spiral cell with a Varta LA95 AGM. Looking at Varta's data sheets, one showed a graph for charging voltages which were very close to the spiral cell stock settings.
