Wanted hymer alloy wheel plastic centre(Now sorted)
The laird
Rally Organiser
Looking for one of these been to,d not available but most hymer dealers are shut7BC9E1B1-961F-4367-9001-C991630C8CC6.png
Try Knowepark in Livingston, they found me a part that a other dealers said wasn't available and it was all done via email (y)
Regards,
Del
Found only pkop stamped on hub centre inside will wait till dealer open and see the state of play
IF you don’t have any joy Gordon, you could always find someone with a 3D printer. It would be plain plastic, but the graphics could be sorted for you at this end.
Cheers roger ,today I've actually buffed the broken lug area down and faced up the damaged lug
I've adhered both parts together and leaving for 24 hours to set
time will tell
hope you are both well rog ,regards to darling chris
time will tell
Glad you are (maybe) sorted Big G.
Sounds like a sticky situation you’ve got there!
If you want the join to be stronger, try melting thin wire into the plastic with a soldering iron, and then applying epoxy resin. Gorilla is a good one.
This should give you an idea about what I mean,
