Mobilvetta
Hi I'm currently away in Spain and every so often I hear my water pump switch on and prime the system.
This suggests to me that I have a leak somewhere, but for the life of me I cannot see one. I've checked the boiler connections and felt the floor, it's all dry,
I've checked were the water pump is and the water tank, again all dry, I have checked in the kitchen and bathroom cupboards, again all dry. No sign off any water on any internal.floors,, checked the Internal toilet cassette housing and that's dry as a bone.
I've also checked underneath the motorhome and no sign of any spillage, although it's a double floor so there is no access to see properly between the two floors. I've resorted to switching the water pump off at night so it doesn't disturb us, it probably runs for 2 or 3 seconds every hour or so.
It has done this before when it was one year old and it turned out to be a common fault on some pressure valve on the truma combi boiler that was allowing water through a run off pipe onto the ground, but having checked this isn't the fault this time.
Has anyone any suggestions of what could be causing it, if it isn't a leak. Cheers David
Ps it's been fabulous weather in Spain so far, but I believe we are in for slightly cooler and windy weather for the next few days with some rain.
