Campervanannie
It was the main pump and they tested it this morning and it was really noisy and spluttery so he put a new one on £112 which I didn’t think was bad plus I got him to check my tyre pressure while I was there ?When you say "flushing" are you talking about the main water pump for taps etc or the toilet flush water pump?
If the toilet pump, they can seize due to lack of use or due to "stuff" floating around the flush tank. If you can fish out the pump it can be temporarily released by turning the pump impeller with a small screwdriver, although I would buy a replacement for the next time it seized.
If it's your main water pump, then ignore all that
Good luck with the repair
K
Yes there was and is on the new one.Good to know its fixed. Is there a grit filter in the supply to the pump?
