nabsim
Trev not sure if you can answer but worth a shot, do you know what the minimum memory setting can be for Kali Linux by any chance? Spun up a VM last night on my MacBook and went with the recommended 2Gb setting and disaster, MacBook only has 2 x 2Gb modules fitted which has been plenty for my needs up til last night. Set a scan running and that was it, Kali hardly responding apart from the scan and OSx even worse.
I didn't want to run it from a live drive USB key at the moment until I have got it how I want it so may have to resort to Windows 10 laptop with more memory spending on your answer
EDIT: its a VM running on VirtualBox and 64bit, may have to give 32bit version a go as that should be less memory needs
