I have always used mattress toppers to try and eliminate the uneveness of the various cushions if making up a jigsaw bed.Day to night and vice versa is very important if you are not fit and bendy, some are truly awful needing infill cushions that live under the bed or in a locker, some are simple slide outs but once one side is done there is nowhere to stand to do the other side.
Something you may have found with your Mohican when you had it? If you used both the Overcab and Lounge Beds .... when the lower bed is made up as per the instructions, you cannot put the ladder in place to get to the upper bed. A bit of a flaw and I think is very common in many Motorhomes with Overcab beds?
I moved the position of the ladder clips on mine and also changed how the lower bed works (after doing some measurements, found only pulling one side out and sleeping North-South instead of East-West, the bed is just the same size) and now it works perfectly. And as well as the use of the ladder you have a bench still available for use.
