saxonborg
My starter battery has been showing signs of weakness so I removed it from the moho to charge it on my multistage charger. When I first charged it , it wasn’t on charge long before it went onto float charge. I then removed it from the charger and left it for at least 24 hours and checked the SG of each cell. I did this four times , one cell started off at 1.175 and rose to 1.220 whilst all the other cells started off between 1.225/1.250 and rose to 1.250/1.265. After the last charge the battery showed a voltage of 12.75 volts. Would it be safe to assume that one cell is on it’s way out and I should replace the battery?
