SimonM
I have over the last few weeks uprated my existing solar and battery setup.
I’ve got 2 panels 100w & 120w along with 4 x 110 Banner leisure batteries. What I’ve now added is a MPPT controller, a solar computer panel, along with a 30a B2B charger. Yesterday I acquired a Nasa BM2 battery monitor to enable me to keep an eye on everything.
It’s not that I’ve got a concern about power, apart from a minor hiccup at the end of last year, all of my lighting is LED already, but I do like gadgets and have the time and desire to fit them.
My question, now that I’ve got it all assembled and working well, is this.
After deciding to enter a battery AH value initially as 400, this is because I’m not sure if I should use the 20hr rate or the 100hr rate declared on the top of the batteries. The monitor then showed that after it all settled down that it was at 104% capacity.
I then changed the monitor to 440 which is the “capacity” of my 4 batteries. I left it to its own devices overnight and through the day today.
It’s been quite sunny in between the occasional shower, however, the monitor has been showing 13.4v and 104% charged and negligible charge (I assume that’s because the mppt is saying the batteries are fully charged, so no problem) . My starter battery that also gets a bit of juice from the mppt is showing 12.8v
Should I be worried about it reading 104% charged? Or is it normal?
