Mr and Mrs Tupcox
Our soon ,new to have autotrail vline
It has a fitted solar panel.which has a cheap solar regulator which you have to switch manually between eg or lb.(charging)
We are up grading to lithium for lb side ,with new solar mppt charger b2b .direct to lb ..
So my question is if i change the factory fitted charger for a mppt dual and remove change over switch ,and set it to lead acid because of it charging eg as we'll , would it be ok to have 2 different chargers charging lithium one set at lead acid and one at lithium ..
The lithium battery will be fogstar 460ah drift.and victron mppt and b2b.
