I can't recall precisely, but on the aftermarket kit I fitted to the RAV4, I am fairly sure it activated on Brake Pedal pressing? It may not have been so obvious as you could potentially connect it to the wiring that activates the brake lights (same difference)? It was over 15 years ago so don't recall the details, but I do remember I had to actually fit a clutch switch to the clutch pedal (obviously) so it would disengage immediately.I've had it on a few cars and only one van and on all touching the brake kills it until you either reset or resume so I wouldn't like that.
Not what I'd call precision control.
I would double-check this on the installation diagram and with the supplier. I would be fairly sure a requirement of a Cruise Control system be disengagement on EITHER brake or clutch use?When I press the brake only the speed drops but the cruise control is still working so lifting my foot from the brake and the cruise control
Builds up to the set speed .
Of course you have the instructions which should be right, but it feels wrong not to have a brake sensor.Disengages on the use of the clutch .
Dip the clutch and everything is turned off until you switch it on again
There is one and it is in the instructions.Of course you have the instructions which should be right, but it feels wrong not to have a brake sensor.
If you are sure the brake does not also disengage the CC, you need to check your installation again I think.Disengages on the use of the clutch .
Tell me about it. Been sometimes very difficult to get the right spares like a simple thing like a track rod end .There are a few different systems historically for pre 07 Sevel vehicles, post 07 is an entirely different setup.
This really does not sound correct. The CC should disengage when you brake and then you would use the 'Resume' for it to turn back on and speed to climb again. And if you don't use the 'Resume', or set a CC speed, the CC stays disenaged.Ok using the cruise control mine works like this.
Build up speed to 50mph. Or whatever. Switch on then select memory
And release your foot off of the accelerator the speed stays at. 50 mph.
Breaking you reduce your speed. Foot off the break and the speed then climbs back to the set 50 mph.
Coming to a stop or a junction foot on brake depress clutch and the cruise control turns fully off
You have to switch it on when required.. but you can get to the same speed if you like as that speed is registered in memory
Until the user changes.
The speed limiter
Get to speed set the speed limit. That’s the speeds your at when you turn it on .
You can speed the limit up or down with a click of the up or down switch.
You can change the gears using the brakes and the clutch as normal driving. But the speed will not exceed to limit one has set.
No matter what gear or what speed it’s limited.
That’s the way mine works .
