Trotter
Micro switch system
Plenty of pressure at pump.
I let the on board water run dry. When I realise that, I put 30 litres into the tank. Switched the water pump back on , pump runs, and on stripping the system down, found plenty of pressure at the pump outlet. Tried a second pump. Again plenty of pressure.
None finding it’s way to the taps.
Do I need to prime the system? If so, how?
I have considered charging over to a Sureflow, but I don’t think the plumbing would be good enough for constant pressure. It’s all joints and jubilee clips.
