Pauljenny
Try WD 40 , before anything else.Have to disagree there. What abiut Duct Tape? That is an essential
Worth it to print and laminate this out for guidence ...Try WD 40 , before anything else.
Oooooh, not a good idea, it’s a bugger to get the duct tape to stick after you spray it with WD40Try WD 40 , before anything else.
Don’t forget, Demi, like me, is getting on a bit. I’m really not sure the plumbing would take the constant pressure, again, like me. If the memory worked all the time, not just sometimes, I’d use Wildebus’s idea of turning the water pump of every time I used it.Del yiu should go for a shurflo pump and do away with them micro switch taps they are a wast of space and expensive.
I've just replaced the bathroom tap in the van on to my 4th lolol 12 quid it's not that they have broke its I keep changing my mind lololol.Don’t forget, Demi, like me, is getting on a bit. I’m really not sure the plumbing would take the constant pressure, again, like me. If the memory worked all the time, not just sometimes, I’d use Wildebus’s idea of turning the water pump of every time I used it.
It would save a fortune on buying replacement taps. The micro switch ones are like hen’s teeth.
It’s the amount of jubilee clip fittings that concerns me. There’s a lot of potential points of failure within the system.There is not that much pipe work to worry sbout Del.
Where will that be? Barnoldeswickski ?We can have a look next time I see you OK.
YeahWhere will that be? Barnoldeswickski ?
