Londonboii
I have just installed a Ring RSCDC30 in my van and it is always on error E0 and it is not sensing the supply from my solar panels. I have 2 160W solar panels setup in Parallel.
I have read the manual and E0 fault refers to the source battery being too low. When I start the van it will come out of standby/Sleep mode so I assume this is due to the battery being lower than the controller wants on the van side. The van will start just fine so it must be just under what the controller wants. This is likely to be as I havent driven anywhere recently and I guess I will have to take this out and charge it overnight. However shouldnt the controller still function and charge the batteries from the Solar panels regardless of the source battery voltage?
Is it possible to have the batteries charge from solar even if the vehicle battery is low/disconnected?
When the van is started and the controller comes on it does not seem to be sensing the solar panels at all. Despite them being correctly installed (as far as I know). When I check the voltage at the PV connection on the controller it shows just above 20v. I have set it to prioritise the solar input and even though there is voltage from the solar panels the solar or MPPT symbols on the screen do not show. When I stop the van it will stay active for a while then go in to E0 mode and then sleep.
Is this indicative of something wrong with the installation / solar panels / batteries or a fault with the controller? Or is it simply that the vehicle battery is too low? Is there an order to connecting the wires I may have missed that could cause this?
Hope that makes sense, any help greatly appreciated.
