EnaC
Our fridge has suddenly decide it doesn’t want to work on 12v whilst travelling, it works fine on gas and ehu when parked. Checked fuses but seem fine any other suggestions please?
We often had problems with the fridge not running on 12v and this turned out to be a lazy relay. Might help to tell us the year and base vehicle of your van as someone with a similar van might know more.
It’s an auto sleeper neuvo 2015 Peugeot thank you will check the relay.
We’ve checked all fuses that we can find all seem to be fine even put in new ones but still not working. Thank you ?I had the same problem last summer with my Hymer. I turned to be a fuse in the engine bay. A 50p replacement sorted it but I took it to a Motorhome repair place near me and they charged me £160 and told me the electro block was broken. Van went in with only my the fridge not working on 12v and was returned with no electrics working. I spent £125 to check out the electro block which turned out to be in perfect working order. I then found the fuse after advice here. So have a good look first yourself, It may save you a lot of grief. I have found the hard way over the last 10 years of owning a MH that most of these places know less than I do about repair. Sad but true
No power whilst driving fine on ehu and gas will check out heater thank youWhen you say it does not want to work when driving is it just a case that it doesnt cool anymore ? Or that it appears to be switched off when driving (like no power) ?
when driving a 12volt heater on the rear of the fridge is used - these heaters can fail
They can be easily changed if you have decent access to the rear if not fridge will have to be pulled out to gain access
