Minisorella
Moderator
After seeing your tracker at the meet, I was given one just like it as a Christmas pressie... absolutely chuffed to bits with it! There are heaps of identical looking models on Amazon and Ebay, with different names on them... most of them costing less than the type in the OP. Paul hooked mine up to my leisure batteries in the hab area, so I don't have worry about keeping it powered. I've not had a problem with signal so far, neither GPS nor phone, and the app works really well. Hadn't realised about the 2G!Mine is the tkstar 915 with 120 day battery life , worth noting not all sim cards work, has to support 2G .
You're right about Three. I tried a Three SIM and it just wouldn't work... didn't understand why until I saw Molly3's post above. I switched to one from GiffGaff (O2 network), which works a treat. I stuck a tenner on it and as long as I trigger a call or text every 180 days, that £10 won't expire and should last for years.As long as you avoid ones on Three, any UK one will be fine. However, I've found Asdamobile to be by far the best for a tracker.
