Blow out waste pipe
baden87
Hi
I’m getting stinky smell from waste , tried all usual things , I now suspect a piece of food is stuck in waste pipe
But cannot get to the pipe to give it a **** *** ( no pun intended) blowing down the waste pipe to dislodge said piece of food
So any help would be most welcome
Have you tried a couple of bottles of Coka Cola down the sink.
Drive around to rinse around the inside of the tank, and then let it all out.
I occasionally just as normal maintenance put a hose pipe in my sink hold a rag around it and get the tap turned on
perhaps you could get hold of an spray gun compressor and blast some air down the plug hole,or try the tyre pressure pump at a garage,i always pour a couple of cap fulls of pine disinfectant down our sink hole when we get back from our travels.
I got some stuff from Aldi , I think it was called sink and drain cleaner , you just pour it down the plug hole and it works a treat , it was only about a quid
Hi mate it depends how you interpret the title of the post , if you are being pedantic
Loosen up , and see it as a piece of friendly Witt , ass it was intended ?
Motorhomer is a family friendly website and is moderated to keep it that way.
As I stated in my first post, this thread title was flagged as inappropriate by Google for the family-friendly categories that we are listed under. You used the title knowing what it meant and there were no further words that described what the thread was about.
I know you meant it as comedy and no offence was intended (and I doubt anyone was offended) which is why I a left a post explaining why I had changed it.
A couple of times a year I flush out the gray tank by filling it from the drain tap .keep an eye on the shower drains as overfilling can fill the shower tray .
