Transit n/s door delock
The laird
Rally Organiser
Can anyone suggest a supplier for a n/s/door lock blank off
Want to remove door key/barrel from passenger door and fit a secure blank off
Did something similar once after a failed break-in of a previous van. They had removed entire barrel, so I cleaned the jagged edges up, treated it with zinc paint, then using Sikaflex ,stuck a shaped piece of ally to the inside skin of the door. Then filled and sanded a few times till it was perfect, and sprayed over it. Could not tell that a key point had ever been there! ;)
Have a word with the weldmiester, I’m sure he could turn a billet of aluminium into a blank to sikoflex into place.
On a serious note, I’m not sure about removing an escape in the case of an emergency.
You'd still be able to get out, as would the passenger.
Is it in the handle or separate & on the door
I would just unclip the actuation bar from inside the panel if you just want to deactivate the lock. It was done on my Ducato base
I would just do as simonM has suggested and just take the bar off the lock so that it doesn’t work from the outside,that way it looks right and a simple job to put back to factory spec should you want to
But then they can pop out barrelsl got one blank coming
There’s also a bracket on each inner doors for a strap to go across, high security hab. door .thatchem cat1alarm and disklok
Gordon, you’re supposed to be enjoying this, not fretting about it being nicked.
Mind you, I have woken up after hearing a diesel pull away in the early hours in a panic. Van was okay as was the 107 they would have had to move out of the way before taking the van.
Chill and enjoy, plus it would be a brave or more likely , stupid bu.... to try to pinch anything of yours. Yer a bigyen ?
I am ,spending the wife’s money
