Have a word with the weldmiester, I’m sure he could turn a billet of aluminium into a blank to sikoflex into place.
On a serious note, I’m not sure about removing an escape in the case of an emergency.
Is it in the handle or separate & on the doorCan anyone suggest a supplier for a n/s/door lock blank off
Want to remove door key/barrel from passenger door and fit a secure blank off
Same here it must be a left hand drive doorKev, my own Transit doesn't have key access on the passenger door....2009...Mk7. not modified standard factory.
Got one sorted Andy it is separate mAteIs it in the handle or separate & on the door
But then they can pop out barrelsl got one blank comingI would just do as simonM has suggested and just take the bar off the lock so that it doesn’t work from the outside,that way it looks right and a simple job to put back to factory spec should you want to
I am ,spending the wife’s moneyGordon, you’re supposed to be enjoying this, not fretting about it being nicked.
Mind you, I have woken up after hearing a diesel pull away in the early hours in a panic. Van was okay as was the 107 they would have had to move out of the way before taking the van.
Chill and enjoy, plus it would be a brave or more likely , stupid bu.... to try to pinch anything of yours. Yer a bigyen ?
Why would I want to do that with the garrison in place ?I would blank the drivers side off too
