RoaminRog
Hi Barry,Did you still have to scrub it with that? What was the procedure? Does it contain bleach?
I was initially quite cautious about Wet n Forget, so I contacted the Technical Dept to check if it would have any detrimental effect on either the roof or solar panel, I was assured that it wouldn’t.
Try to park your van with the roof as horizontal as poss, and allow to soak overnight.
In my case, a light brush in the morning together with a hosepipe, was enough to remove 99% of the rubbish on the roof.
It helps if you can apply when there is no chance of rain for a few days.
I have since applied a second coat and simply left it to do its stuff.
Hope this helps, R.
