Tezza33
Whilst at Rutland I was showing Trotter under my van where the bulk gas tank is, he crouched down to look and said he could smell gas, well I knew I had a gas leak (I test regularly) but I couldn't find it, I have no sense of smell and neither has Maggy so this was the first time somebody could smell it, armed with this today I checked every joint on the tank/filter/regulator and pipe work on that side of the van but nothing so I checked the next joint in the pipework which is a T piece in the old gas locker, I have checked this a few times over the last Month but nothing was showing but it was obviously getting worse, this time I had the tell-tale bubbles from the leak detector spray, this is what I found when I removed it
the nut had split, this probably started very small but gradually got bigger, I checked the pressure left in the system after turning the gas off and it stayed in the green for 45mins at which point I thought it was the time for a celebratory drink
thanks for your nose Del
