rugbyken
you might struggle with that. the Mains Adapter quotes the output as 2500mA (2.5A) at the DC voltage. The typical USB Output is either 1A or occasionally 2.1A.hi steve i have an 12v multi adaptor with a 5v usb port , if i could find a cable with the right adaptor on it would be perfect,
The approach I took when I adapted my Amazon Echo to work on 12V instead of 240V is the following:getting the correct jackplug is the biggest problem i can foresee there are so many different ones and identifying it is first step
Thought I would add a photo to illustrate what I was talking about ....The approach I took when I adapted my Amazon Echo to work on 12V instead of 240V is the following:
You can then just switch between the 240V adapter at home and the 12V adapter in the Motorhome by swapping the source plugs over. This saves trying to find a matching jackplug from the myriad of different sizes.
- Cut lead between 240V adapter and jackplug
- Fit a connector on each end of the cut wire (so they can be reconnected again). I used these - https://amzn.to/2Ywlfwi - but lots of socket and plug combo styles around
- Fit another to the output of the DC Adapter you are getting
IMG_20190705_192127 by David, on Flickr
