Tezza33
I have posted on another thread about the gas leak which I am struggling to find, 36ltrs gone in three days so even Charlie wouldn't have used that much.
By turning off the isolating valves and checking for a pressure drop I found no leaks, turning on the valve to the water heater there wasn't a drop in pressure, turned on the hob valve and still no drop in pressure even after a few hours, closed them and opened the fridge valve, preesure slowly dropped over 8 minutes so the problem seems to be from the isolating valve to the fridge itself, I have check all the joints including the ones to the gas valve/thermostat, still cannot find the leak, I wish I had hair then I could pull it out
I have to remove the hob to get to the top of the fridge and remove the rear bumper to gain access to the jet, I do have a good flame although
I don't think that would burn 12ltrs a day
