sydnsue
We have a Whale water system. There are 2 problems. The outlet in the connector is tiny which means even with decent water pressure, it takes ages to fill. The other problem is when we can only find taps with no screw connector. We have a rubber cone type connector to push on the tap but due to the back pressure caused by the tiny outlet, its impossible to hold on the tap.
Has anyone found any better ways to refill. We have the pump but that takes around 10 minutes to pump 1 bucket.
