Hi advice on a second battery .
Do I need to buy the same as my original or can I buy any on the market .
Regards Pete
Stick with the varta and or add an extra one which will give you a longer run of power,lithiam in my head is not worth the extra money.You could by a cheap battery of the same size ,when they fail you won't have lost much ,, I did they are now in their third year .first signs of failure I will replace with 2 varta . ?? Getting more tempted to go lithiam,
Cant disagree trev ,but it is also about space and weight in a small van ,Stick with the varta and or add an extra one which will give you a longer run of power,lithiam in my head is not worth the extra money.
My new van came with a 70A/h leisure battery . Thought about buying 2 x 120A/h .Hi advice on a second battery .
Regards Pete
