SimonM
I have been watching my battery monitor for many weeks and can see a small discharge despite everything being switched off.
I have disconnected every circuit to the leisure batteries, not easy as the starter battery is also incorporated via the extra wiring allowing the solar to charge the starter.
then each circuit has been individually tested with a meter to prove there is zero current flow.
putting everything back together all seems well, the solar sticks plenty of power back in, the alternator circuit when the engine is running pumps in plenty too when required and the battery monitor soon shows the system is topped up nicely with amps and volts.
and then overnight it shows anywhere between 85 and 90% full, and starts to rebuild when there’s a bit of daylight around.
the one thing I haven’t taken out of the equation is the inverter which is wired directly to the leisure batteries via a couple of very heavy duty and short wires. It is always switched off.
however, does is consume any power even when it is actually switched off? Reading the instruction manual is shows it has a 0.45a discharge in standby - I was assuming that is switched on but not actually doing anything.
Thought please.
Thought please.
