I think that as my w.c doesn’t have its own pump but relies on the main water supply there will not be a fuse. Thanks anyway.
Sounds like we need another fix-it meet. Anyone?
Yes please can you all come to Portugal I can fit 12vans in the garden.
As my van is 1994 I think you may be correct.It sounds like you’ve got the old style Hymer with the long cassette and the rotary flush arrangement ?
Thank you so much for the links it would appear that I have the c2 / c3 I will investigate further when we get back but away at the moment and flushing with a pail . The joys of older vans.OK, can you not completely remove the cassette and get to the switch either from the outside or through hole inside the van ?, if necessary use a mirror to look inside, also if you go to the Thetford site and check out their tutorials about servicing your unit, I've got the C200 and I'm sure that's not your model, what you need to do first is establish which model you've got, below are some links which may be helpful, on their site I can download just about everything (tutorial) for my C200, yours looks like it may be the C2, C3 or C4
Dropbox
www.dropbox.com
Thetford Cassette Toilets - Thetford Spare parts/accessories | Leisureshopdirect
Thetford Cassette Toilet spares for caravans and motorhomes at the lowest prices. Technical drawings and good descriptions to assist you in your search to find the correct spare part for your Thetford cassette toilet.www.leisureshopdirect.com
Thetford - Convenient Solutions For RV Adventures
Discover our wide range of mobile sanitary systems, cooking and refrigeration appliances, toilet care and maintenance productswww.thetford-europe.com
Hmm. We try not to use any flush water. If you are careful, the waste goes straight down the hole.away at the moment and flushing with a pail
Thanks you are correct that using a pail quickly fills the cassette but as we only go for two days at a time ( because of home commitments) it has not been a problem ,but today I suddenly realized that with the shower head just above the w.c. It was easier to use that. However when I got home today and removed the toilet roll holder and got a mirror I spotted a relay hidden at the most awkward position so after carefully removing it I found a lot of corrosion on the contacts have cleaned them but not sure how to test will find out tonight.Hmm. We try not to use any flush water. If you are careful, the waste goes straight down the hole.
If you want to do more, use a hand sprayer to rinse the bowl.
Using a pail to flush will dramatically reduce how long you can manage between empties.
Hi. I checked the relay and it is totally dead it appears that water has got into it from the shower I can only think that there was a leak at some point. On Monday I will go to our local town to try to get a replacement and then see what happens .Check the bottom of the relay there should be schematic diagram of the relay, there should what looks like a box with a line through it, with two lines, one in one out, they are the connections for the relay coil, put the pos/neg across them and you should hear/feel it “click”, most relays are normally open and normally closed and a common connection in
Hi . Managed to get a new relay today (had the old one tested it was completely dead ) fitted it this afternoon still not working! Back to the drawing board.If you can’t get one in the town try Ebay and look for a 12v relay, it’s unlikely water has got in as they are normally sealed ?
Thanks but as it is a plug in unit it must be correct I also checked that the pins were in the same position as the faulty unit .I will get the meter out today and see if can sort it.Not being funny are you sure you connected it correctly ?
If you slip the cassette out you will see the 3 amp fuse ,it helps if you have a good torch. You cant miss itHi everyone.
Does anyone know if there is a fuse on the W.c electric flush on my elderly Hymer ? For some reason it’s stopped working I know water is getting to the unit because if the system is full a small amount runs into the bowl when the flusher is pressed but the pump fails to kick in ( works on all other taps) . Looking in from the cassette end I can see the bottom of the electric switch but to far to reach for investigation as it is old plastic I am unwilling to try removing without knowing how it dismantles.Any helpfully suggestions ?. Thanks in advance.
