Sapper
Hello,
I currently have one LB wired up with split charger however I also have a further two LBs taken from my old Campervan. I know I can link two together (which I feel is a good idea) and even all three however I want 12v power at the far end of my camper (6m away) so wondered if I should either:
a. Place third LB at the rear and use it completely separately,
b. As a. Above but also link it with the other two LBs so it is charged by vehicle,
c. Locate all 3 LBs together at front, linked together so all receive charge and run a feed to the rear,
d. Or another idea???
NB. All LBs are same capacity and rate but different makes and age, not sure if that will make any difference?!
thanks,
chris
thanks,
chris
