sydnsue
My alarm was already fitted so probably runs from the 12V circuit.no all the alarms will still work they run from a 2nd battery the my friend fitted
Our van (Transit) was stolen and, apart from changing the door lock , we've fitted a pedal locking box.I am looking to improve "drive away" security and night time security. First, has anyone had a hidden kill switch fitted? I have a Peugeot Boxer base. Having read many articles, the kill switch seems to be a cost effective method. It seems most locking clamps are easily removed and are only good to stop the opportunist. Is killing the battery the only method because I assume that also kills the alarm system and door locking? It would seem better to just kill the engine.
I have taken the view with habitation security that it is impossible to stop break-ins. No matter what you do, ripping out a window is easy. I have window and door alarms and a motion alarm. Personal security is what I wish to improve. We use the seat belts to restrain the cab doors but the habitation door is the obvious problem. I rely on the alarms to wake us if a door or window is opened. Does anyone have any other ideas to improve night time security? We mainly wildcamp and always move on if we don't like an area but it would be good to increase peace of mind.
Very good to have changed the Tibbe cylinder for something more secure. You might also consider impeding access to the OBD port, which is used to overcome the OEM immobiliser.Our van (Transit) was stolen and, apart from changing the door lock , we've fitted a pedal locking box.
Pedal Box Fiat Ducato 2006-2011
MOTOR HOME OPTION AND PEDAL LAYOUT OPTIONS: Due to Fiat motorhomes having various pedal layouts we will require a good clear image of the vehicles pedals.This will enable us to send the correct pedal box to you. You will also be required to enter your vehicle registration.garrisonlocks.co.uk
I've also fitted one of these in the driveway :- https://www.barriersdirect.co.uk/parking-posts-residential-c1087/telescopic-parking-posts-c1158
And just for show - a steering wheel clamp. "Every little helps"
Cheers Spike
That system poses problems with the Transit unless you have something other than the OEM Tibbe lock cylinder for locking/unlocking the cab doors.We use a simple yet effective system like Cronkle. It works well for us, at night and when leaving the van - we simply fit the bar and exit via one of the cab doors.
We've also fitted a webbing loop to each cab door that fits over an extended screw on the frame. They work like a door chain for nighttime peace of mind
What is Cronkle. Can't find anything on it.We use a simple yet effective system like Cronkle. It works well for us, at night and when leaving the van - we simply fit the bar and exit via one of the cab doors.
I am assuming you are switching the fuel pump. Would it be possible to drive a short distance with no pump or does that effectively immobilize the engine instantly.There should be wires going to the fuel sys,these can be interupted with a remote switch or a fuel cut of solenoid can be fitted somewhere leaving the tank with a remote switch.
And can also be used for chopping wood .I am sure folks think I am joking whenever I post in security threads but I keep an axe to hand. The dogs go mad when anyone come near so always wake me.
Our pug 2017 motorhome is standard fitted with a ignition switch with a red ring around the switch when you turn of the engine you can turn 1 click further and after 7 minutes it isolates the running battery doors will be disabled and all engine electricalI am looking to improve "drive away" security and night time security. First, has anyone had a hidden kill switch fitted? I have a Peugeot Boxer base. Having read many articles, the kill switch seems to be a cost effective method. It seems most locking clamps are easily removed and are only good to stop the opportunist. Is killing the battery the only method because I assume that also kills the alarm system and door locking? It would seem better to just kill the engine.
Thanks for everyones help on this. I have decided from the advice I have received to fit a fuel pump isolator switch.
For drive away I use a Clutch Claw it’s easy to use and it was recommended by my insurance Company “Caravan Guard “ I’ve not known an insurer recommend anything before so it must be good. To remove it without the key it certainly would not be easy. Just look for Clutch Claw on the internet, I also use one on my 4x4 Jeep.I am looking to improve "drive away" security and night time security. First, has anyone had a hidden kill switch fitted? I have a Peugeot Boxer base. Having read many articles, the kill switch seems to be a cost effective method. It seems most locking clamps are easily removed and are only good to stop the opportunist. Is killing the battery the only method because I assume that also kills the alarm system and door locking? It would seem better to just kill the engine.
I am looking to improve "drive away" security and night time security. First, has anyone had a hidden kill switch fitted? I have a Peugeot Boxer base. Having read many articles, the kill switch seems to be a cost effective method. It seems most locking clamps are easily removed and are only good to stop the opportunist. Is killing the battery the only method because I assume that also kills the alarm system and door locking? It would seem better to just kill the engine.[\Quote]
