sydnsue
I have several devices that require charging in the van.
1. There is a high power drone battery charger that I run from an inverter. Input 240V 1.8A. Output 17V 3.53A.
2. There are 4 USB devices that prefer the fast charge socket which I assume is the 2.4A type. I have searched for multi sockets but they all seem to be 2 x 2.4A with 2 x 1.0A. Has anyone found a 4 way 2.4A?
Obviously I need to run a new high power fused cable to the leisure batteries. Should this be connected directly to the battery terminals or is there another method?
What size cable and connectors should I use to allow maximum charge capacity? 4x USB will be 9.6A plus the inverter for the drone charger.
