not trying to. but hopefully others will read this and won't follow your flawed exampleBeen full timing on cheapos for 6 years I would agree they have had a rest this year.. . you wont convince me...
Each to there own .not trying to. but hopefully others will read this and won't follow your flawed example
At £499 they are getting closeNo thanks cheapo for me..
When lithium are £200/£300 I mite be tempted..
They are which is great .At £499 they are getting close
Good thread David a bit above my low tech skillsIf it's of any interest, you could have a look at my thread on the motorhomebuilder site here -
https://motorhomebuilder.com/threads/turbo-charging-motorhome-electrics.67127/
It covers what I did when fitting 300Ah of Lead Carbon batteries (which have quite similar properties to Lithium in terms of charging speeds) in my Autotrail Motorhome fitted with a Sargent 325/328 PDU.
I would have gone for the Poweroad Infinity Subzero except the budget didn't allow it. If I DID go for Lithiums, my install would have remained exactly the same except for the actual batteries.
I couldn't agree more, as a full-timer refillable gas saves me money but lithium keeps me off grid for much longerIts getting what is best for you. If you need a lot of power all year round its much different from lower power users. Its finding what works for you that's the trick
Didn't you say previously, you've gone lithium? How you getting on with them and an approximate cost?Its getting what is best for you. If you need a lot of power all year round its much different from lower power users. Its finding what works for you that's the trick
Yes I went lifepo4 after killing my Bosch/Varta powerlines, I just pulled far more than they could cope with, would have needed a lot more than the three I had. The lithium works well for me and not had any problems since changing over to them. Weight is ridiculous, even I can move these around at 13kg each, the pair of them weigh the same as one of my old ones.Didn't you say previously, you've gone lithium? How you getting on with them and an approximate cost?
Rightly or wrongly, I've gone the carbon lead agm route. I can confirm they are b.... heavy. But, they were within my budget, just. My main concern is how fast they take a charge from solar. The B2B is fine. Not had enough sunshine vs load to make a decision.
A lot of these new >3.5t motorhomes seem to have stupid low payload Caz so I suspect quite a few will be glad of the weight savings of lithium. Prices continuing to drop so getting better option all the timeMy reasons for for considering lithiam are size of battery 1 x 100amp not 2 x 100amp lack of storage space .weight saving 13 klg , not 46 klg as 2 lead acid ,less risk of overloading and back ache fast charging is a bonus but not essential .Thanks all for replies.
Proberbly even cheaper then, be nicer to nick just keep trotting aroundWhen, not if, Nik kicks me out. I'll possibly go that route. As I'm still very much part time (atm) I'll see how these AGM's workout.
Spot on Neil ,my van is 300 klg pay load Alpha batterys 100 amp poweroad £ 499 , did you go top of the range or economy .A lot of these new >3.5t motorhomes seem to have stupid low payload Caz so I suspect quite a few will be glad of the weight savings of lithium. Prices continuing to drop so getting better option all the time
They will take everything your solar can send them.Didn't you say previously, you've gone lithium? How you getting on with them and an approximate cost?
Thank youThey will take everything your solar can send them.
I did a test of the Relion 100Ah Lithium (LiFePO4) against one of my 210AhNorth Start Blue+ Lead Carbon 210FT (PbC).
Taking the LiFePO4 down to empty gave me exactly the the wattage output as the PbC down to 50%
Recharging the PcC back to full took no longer than recharging the LiFePO4 back to full (using a charger limited to 50A Rate for both)
100Ah Lithium lighter for sure than 200Ah of Lead Carbon
200Ah of Lead Carbon cheaper than 100Ah of Lithium
200Ah of Lead Carbon lot more usable capacity than 100Ah of Lithium (you can go a lot lower than 50% if you want).
