Winter time
Good point. Maybe not the ideal then. Back to the old “watch the forecast and drain if worried” technique then. Hey Ho.
How about adding some salt, Salty water shouldn't freeze you could work out the mix by trying some in your freezer
Salty water does freeze, I have encountered it numerous times when wildfowling on the solway Firth.
This was the Isle of White a few years ago -
I have also experienced sea freezes in Strangford Lough, an almost enclosed sea Lough with river estuaries which can freeze. On a rocky shore the beach becomes quite a sight as when the tide drops the ice sheet buckles to the underlying shape of the ground. It rises again on the flood and becomes more distorted as each ebb tide further distorts the ice sheet.
However I wonder if salt introduced into a fresh water system would be detrimental to pipes, taps and other fittings.
Davy
Salt water is abrasive if it has crystals of undissolved salt in it.
It would damage all working parts seals pump.boiler.
Reactions: RCW
OK so now we have gone full circle. Let’s start again and try to find how people prevent the loo flush water from freezing. The candidates so far are:
A small amount of the non toxic antifreeze disposed into the mains sewerage system. It would seem that the consensus is the amount involved would not present a problem to the sewage purification plants.
Adding a salt solution comes a poor second with poor antifreeze properties and possible damage by undissolved crystals.
Any further suggestions that do not include medical procedures on myself? I cannot believe this is the first time this problem has been raised?
